Re: Farmall A governor/throttle linkage help
Posted by Kevin on February 02, 2015 at 16:42:48 from (174.236.34.215):
In Reply to: Re: Farmall A governor/throttle linkage help posted by gene bender on February 01, 2015 at 12:02:51:
Is the governor arms supposed to move free forward and backwards with the linkage removed? Linkage from carb removed my gov arm moves free front to back with no tension. Which position should the arm be in for this adjustment? Or is it not supposed to do that?
  Upload Photo  Select Gallery Photo  Attach Serial No List
