Re: Farmall A convertion to 12V negative ground
Posted by Bob on February 02, 2015 at 18:34:01 from (64.255.159.192):
In Reply to: Re: Farmall A convertion to 12V negative ground posted by dhabeck on February 02, 2015 at 18:15:50:
The ignition current through the coil (with the breaker points closed) should be in the 3 to 4 Amp range.
More draw than that would indicate you are using a coil with low primary resistance that needs to be used with a ballast resistor.
  Upload Photo  Select Gallery Photo  Attach Serial No List
