Re: IH 606 Hydraulic pump upgrade
Posted by gqjoe on February 03, 2015 at 18:47:35 from (173.210.167.202):
In Reply to: IH 606 Hydraulic pump upgrade posted by gqjoe on January 09, 2015 at 22:29:32:
I wanted to post an update on my progress. I installed the new pump and suction tube and it went together very easily. On the filter side input on my filter extender kit but noticed that the filter had a large opening on the exterior side. After some research I found out that I needed to order a filter bypass valve before I put the filter, extension and lid on the tractor. I did that and that side went together very nicely too! Also when putting on a dry pump I filled the pump with oil through the hole where the filter attaches until it came out before I put the filter in.
It started and now it sounds way way louder than it did before. It whines and it seems to get a little quieter when I steer left or right. The whining also seems to be coming not from the pump below which I would say indicates gears clashing but it's coming from the flow divider valve area. I'm hoping I could get some help with this yet as to what I should check out or test.
  Upload Photo  Select Gallery Photo  Attach Serial No List
Today's Featured Article - A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w ... [Read Article]
