Re: Farmall a governor questions continued
Posted by WellWorn on February 04, 2015 at 16:11:09 from (75.193.124.108):
In Reply to: Farmall a governor questions continued posted by Kevin on February 04, 2015 at 15:57:25:
Kevin, check the shaft that goes into the gov from the throttle lever (in front of the distributor/magneto). Put the throttle lever about mid position to check it.
I know mine acts a lot like yours does, and that shaft/bore hole is significantly worn.
