Re: Farmall a governor questions continued
Posted by Kevin on February 04, 2015 at 18:23:54 from (174.236.6.92):
In Reply to: Re: Farmall a governor questions continued posted by WellWorn on February 04, 2015 at 16:11:09:
With throtle mid position i can definately grab the arm on the
distributor side and wiggle the shaft a bit. Both shafts actually,
distributor and carburator side. Is this the orgin of my problem?
Does anyone make a rebuild kit to fix this?
  Upload Photo  Select Gallery Photo  Attach Serial No List
