Re: Another question. Starter this time.
Posted by cole in mo. on February 04, 2015 at 17:17:51 from (65.255.149.240):
In Reply to: Another question. Starter this time. posted by rjc2rjc on February 04, 2015 at 17:14:23:
You may have knocked the ring gear loose on the flywheel, starter is turning that, but not the flywheel. Or the 12 volt jolt may have messed the bendix.
  Upload Photo  Select Gallery Photo  Attach Serial No List
