Re: Another question. Starter this time.
Posted by old on February 04, 2015 at 17:25:27 from (72.251.71.173):
In Reply to: Another question. Starter this time. posted by rjc2rjc on February 04, 2015 at 17:14:23:
Could be a loose ring gear like Cole says. Could be a bad starter drive. Or it could be burrs on the ring gear teeth which can also cause that
  Upload Photo  Select Gallery Photo  Attach Serial No List
