Do you know what the bendix on the starter is? That is the toothed section about 1 1/2 inch diameter on the end that moves in and out to engage the ring gear. If those teeth are all chewed up, the solenoid is pulling into the proper position and it is "Chattering" on the ring gear. Replace if chewed up. Make sure the starter is flush and tight. If not chewed up the gear on the flywheel I turning . Check that .
Today's Featured Article - Fabrication (Who Me? Make it myself?) - by Chris Pratt. First of all, what are the reasons for not fabricatin your own parts? Most judgements on what should be purchased rather than fabricated stem from: Originality - If the tractor restoration is to be 100% original, it is likely that you should spend the time and money to locate the component in the used or New-old-stock market. Since this can be extremely difficult, you may want to fabricate the item or purchase a modern replacement temporarily, but eventually, you s
... [Read Article]
Latest Ad:
[More Ads]
