Re: h and m draw bar
Posted by rustyfarmall on February 07, 2015 at 06:59:10 from (208.126.186.41):
In Reply to: h and m draw bar posted by mike in mo on February 06, 2015 at 21:03:34:
The early Ms and Hs used the same horseshoe. In later years the M may be thicker and heavier. Most of the horseshoe drawbars on Ms, as well as a few Hs, were modified by welding a steel flat bar underneath the original horseshoe, and then the holes were drilled out.
