Posted by FBH44 on February 07, 2015 at 12:48:48 from (64.85.216.28):
1950 "H", have had some problems in past, when I installed the wavy=4-bolt coupling thing in the drive shaft backwards. [And yes, it will fit in backwards...] Anyway, 4 months ago, the dealer split the tractor, ground the flywheel, put in a reman pressure plate, kept the same clutch plate same thickness and looks just like a new one, kept same thro-out bearing looks buttery smooth and perfect thickness, looks like new one. I have the pedal arm rod adjusted to be 1 1/8" away from the transmission cover. Cannot figure why it has begun to is grind going into 1st or R. Everything ought to be perfect, but after driviing it only 25 miles, with no hard work at all, this morning it grinds bad going into 1st or reverse. Grinds one time, then it will not do it again until shut down, when it will grind bad again. Stumps me. Any ideas, guys? I'd really appreciate it.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
