The easiest way to tell if you are getting a good release on the H is to take the plate off underneath behind hydraulic pump. You can reach up and turn the clutch shaft while depressing clutch pedal. Transmission in neutral and engine NOT RUNNING OF COURSE, A good clutch will release well before end of pedal travel. Just one finger being misadjusted will cause your problem or disc not moving feely on the splines. At least you can satisfy yourself if clutch actually releases properly. Like someone else said, just light oil in transmission will make those gears coast a lot longer. A little burnishing of the clutch may also help like suggested. My old '37 ford had to be run up against a tree every once in a while to polish up the clutch.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
