Posted by rustyfarmall on February 08, 2015 at 05:55:32 from (208.126.186.41):
In Reply to: H bad fuel posted by john4689 on February 08, 2015 at 05:43:01:
Your tractor will run just fine on today's gasoline. The carburetor is still dirty. It needs cleaned again and adjusted to factory initial settings. A full ignition tune-up would also be in order.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha
... [Read Article]
Latest Ad:
[More Ads]
