Posted by john4689 on February 08, 2015 at 05:43:01 from (50.32.221.200):
About eight years ago the fuel went bad ,over the winter, in my 1940 Farmall H.
I cleaned the rust out of the fuel tank and cleaned the carburetor but it has never run right since then.
I have owned the tractor for 20 years and it ran perfectly when I got it.
It runs OK at 1/2 throttle ,but misses a lot at other speeds.
I have been using it as-is for the past 8 years but I am taking it to Beiler's auction in Lancaster Pennsylvania next week and I would like to get it to run a little better.
When I adjust the needle valves on the carburetor, It makes very little difference, almost as if the carb. is still halfway clogged up.
I have had the carburetor apart 3 times, over the years (most recently yesterday) and I just can't find anything wrong with it.
I suppose it could be an ignition problem. I can't remember the last time I replaced the distributor points. I filed them yesterday and have a new set on order. The spark plugs are new and the distributor cap and spark plug wires look OK.
The original 6 volt ignition coil fell apart some years ago and I fitted an old 12 volt coil that I had laying around. I used to have an adjustable resistor in the wire feeding the coil, but now I just feed 12 volts straight into it. Is it possible that the full voltage is too much?
Another odd thing - one time I ran out of gas and put a couple of gallons of 2 cycle chainsaw fuel mix in the tractor , and it ran like a champ!
Is it possible that my old tractor just won't run on the new type gasoline ?
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha
... [Read Article]
Latest Ad:
[More Ads]
