Re: H bad fuel
Posted by Notjustair on February 08, 2015 at 06:36:19 from (70.195.1.222):
In Reply to: H bad fuel posted by john4689 on February 08, 2015 at 05:43:01:
If your adjustments don't phase it one way or another it is still
clogged. With what it sounds like, it may be rust in there
causing issues not a true trash plug up. I've been working on
carbs for a lot of years and it is still a miracle if I get it fixed on
the first go around, likely that I will get it done on the second,
occasional that it takes a third try, and if I need to pull it apart a
fourth time I just bang on everything that's in there. It happens.
Just because you did it three times doesn't mean you caught
it.
Lay a feed sack on the work bench and tear it apart again. Use
an entire can of cleaner on ever nook and cranny (I didn't have
carb cleaner the last time so I used ether and it worked VERY
well). I just did my chore pickup last week and it took two tries.
The only thing I can get in one try is the old down draft Holley
on the grain truck, but she and I have been dancing for years.
  Upload Photo  Select Gallery Photo  Attach Serial No List
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
