Posted by rustred on February 08, 2015 at 08:18:08 from (74.214.152.80):
In Reply to: H bad fuel posted by john4689 on February 08, 2015 at 05:43:01:
your outlet in the tank going to sediment bowl most likely is the case of that. the stand pipe piece on the sediment bowl is partly plugged. I have experienced this on my 1550 cockshutt. it sat for about 20 years and the tank got rusty. had the tank off a couple times and cleaned the best I could. it was good for a bit each time but eventually more rust would get into the outlet pipe. I fixed the problem this summer. I drilled out the stand pipe to fit a piece of 3/8 copper line. I then pushed in a piece of 1 1/2" of copper line into it and this fixed the problem. I baled round bales with the tractor this fall and she was working hard and no shortage of fuel. just have to remember that tank empty level is raised that much. the other option was to coat the tank but thought I would try my fix first.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha
... [Read Article]
Latest Ad:
[More Ads]
