Re: H bad fuel
Posted by Icuby on February 08, 2015 at 15:06:59 from (70.198.38.251):
In Reply to: Re: H bad fuel posted by Oregon Tractor Jack on February 08, 2015 at 08:42:09:
If I have to clean a carb,I use oven cleaner and let it soak a while. Works good for me.
  Upload Photo  Select Gallery Photo  Attach Serial No List
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
