Re: H bad fuel
Posted by Oregon Tractor Jack on February 08, 2015 at 08:42:09 from (50.137.138.152):
In Reply to: H bad fuel posted by john4689 on February 08, 2015 at 05:43:01:
Your carb is still plugged. I rebuilt an H that was stuck an hadn't run in years. Went through the whole tractor. The carb gave me the most fits. Tractor would start but only run with the choke half way out. Took at least four tries to get it cleaned out. Go buy a tip cleaner for an OXYAcetylene torch. They have a bunch of stiff tip cleaners in really small sizes. They work well for all of those tiny holes in the carb. Lots of compressed air and carb cleaner. Once you think you have it clean, do it all over again.
  Upload Photo  Select Gallery Photo  Attach Serial No List
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
