Re: IHC 340?
Posted by Janicholson on February 08, 2015 at 16:30:00 from (74.60.94.18):
In Reply to: IHC 340? posted by gabeS. on February 08, 2015 at 16:08:14:
IH engines had no seals in that era. They need seals, and the seals can be purchased from NAPA or? to fit the guide and valve stem. Even umbrella seals are better than nothing. If a valve is allowing too much oil to get past the guide, it probably has more than .002" side to side play, and needs a guide, then the valve reseated. Jim
  Upload Photo  Select Gallery Photo  Attach Serial No List
Today's Featured Article - Tuning Up Your Tractor: Cooling and Fuel Systems, Hoses and Belts - by Curtis Von Fange. Our tractor is coming right along. The old oil and filter has been taken to the recycler and the air filter replacement has breathed new life into our motor. Let's take a closer look, now, at the cooling system since it has to work so hard in the summer heat. Cooling systems can be real cantankerous in their old age. Radiator cores clog up with rust, lime or other mineral deposits and the fins clog up with weed seeds and debris. The metal headers slowly corrode away from years of use and ... [Read Article]
