Re: farmall M help building BIG motor !
Posted by The tractor vet on February 08, 2015 at 20:44:10 from (104.179.81.68):
In Reply to: farmall M help building BIG motor ! posted by boot on February 08, 2015 at 19:02:19:
Well if you want to GO BIG , just how big do you want to go ?? Sleeves for get them unless you bore into the water jacket . Copper head gskt for get it and go with O/Rings and fire rings . As for a stroker crank here ya weld up and off set grind and ya start looking for a connecting rod that will work with what piston you decide to use with the bore you can get and once you figure out your pin setting in the piston to the compression distance then you can grind the crank to fit the rod . . Now as dropping your money at Denny's Carb shop it is your money but he is a RIP OFF . To start with ya need a progressive engine size book and you can go blind looking at all the spec.'s on ever engine part ever made and it will give a part Number for each sized part , pistons rings valves springs bearings you name it it is in there . The engines i have put together non of the parts that went into it did not come across the dealers part contour . One 4 cyl. M M engine that started life as a 335 Cu. In. when done was 609 Cu. in with real close to 13 to 1 NTC-855 Cummins sleeves , Allison 5.560 pistons farmall M rods John Deere valves . and from the outside it looked stock . On one other we used Massey rods and Mack sleeves and GMC V-6 pistons . One thing about building a tractor engine your not going to be spending a lot of time at Summit or Jeg.'s your not building a Small block Chebby .
  Upload Photo  Select Gallery Photo  Attach Serial No List
