Re: H bad fuel
Posted by john4689 on February 09, 2015 at 18:58:42 from (50.32.221.200):
In Reply to: H bad fuel posted by john4689 on February 08, 2015 at 05:43:01:
That is interesting about the coil. I have not checked it lately, but my coil used to get really hot. I was concerned that it might burst from the heat, but it never did.
Some years ago I had a rheostat (variable resistor) connected to the input side of the coil and ,now that you mention it, I do recall that the engine did not run well with the full 12 volts supplied to the coil. I forget why I took it off.
I have a new coil and resistor on order.
There is some new dirt (rust) in the fuel sediment bowl that I had not noticed before, so I ordered a sediment bowl gasket , so I can clean that out.
The float valve is leaking now, so it looks like I will be taking the carburetor apart AGAIN for the fourth time!
I still have a week to fix this before it goes to auction!
This post was edited by john4689 at 19:02:52 02/09/15.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
