Your spark is weak. When the current draw of the starter pulls the battery voltage down, the spark is too weak to fire the plugs.
Could be a weak coil, or perhaps you have a coil that does not need an external resistor and there is one in the circuit, or even a bad coil wire or cap or rotor.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
