Posted by Janicholson on February 11, 2015 at 15:27:23 from (74.60.94.18):
In Reply to: 1951 Farmall M posted by Walt In Jaxn Tn. on February 10, 2015 at 20:36:33:
The bypass port on most letter series engines is so big that the thermostat usually does not open unless using full power for tillage or belt/pto work. The bypass can be restricted to 1/4 " hole to assure better thermal warm up. The bypass is at the sp;it where the thermostat is placed, cast into the housing. It would need a stainless steel plate made like the gasket, and a smaller hole where the D shaped bypass is located. 2 new gaskets might be needed, or Permatex #2 on one side. Jim.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
