Re: H bad fuel
Posted by john4689 on February 14, 2015 at 17:48:29 from (50.32.221.200):
In Reply to: H bad fuel posted by john4689 on February 08, 2015 at 05:43:01:
I got it fixed! It was the ignition coil. The old one was bulged on the bottom and cracked at the top. I installed a new coil and hooked it up properly with a resistor so that it gets full voltage only when the starter motor is cranking and a diode so that the current does not back feed from the coil to the starter.
The only problem was when I removed and re-installed the starter cable, the 3/8 inch stud spun in place and twisted off the field winding connection inside the starter.
I tried to repair it by silver brazing an extension to the copper winding and bringing it out through the hole in the starter body.
The starter repair did not work. I am not sure what went wrong, I used some fiberglass sleeving and brush on electrical tape.
I must have pinched something when it went back together. I did not have any more time to fool with it so I ran out and bought a rebuilt starter.
I am still amazed by the fact that the tractor is 75 years old and my dealer (Messick Farm Equipment, Elizabethtown PA) had the starter in stock!
The price was reasonable, I could have bought one on ebay for a little bit less but it was worth it to me to have it right away.
This post was edited by john4689 at 18:01:05 02/14/15.
Today's Featured Article - The Fordson F Ignition System - by Anthony West. A fellow restorer contacted me earlier this year asking for some help and advice on a model F that he was restoring. He had over a period of months spent a fair amount of his hard earned cash on replacement parts for the old "trembler" ignition. Sadly though all his efforts seemed to be a waste of time and money as he still couldn''t get the temperamental old thing to run correctly!! If i said that this was a little frustrating for him that would be "conservative" in fact the problem had reduce ... [Read Article]
