Re: Electrical Issue With International Harvester Frame Is H
Posted by Commoner#5 on February 16, 2015 at 06:06:14 from (108.49.89.244):
In Reply to: Re: Electrical Issue With International Harvester Frame Is H posted by WellWorn on February 15, 2015 at 12:08:35:
Great idea, thank you all. I just found out that
this key switch is called a battery disconnect
switch. There seems to be an issue with it. I
will use jumper cables and try. I will remove the
ground cable from the negative battery terminal
and hitch the jumper cable to negative and the
other end to the starter bolt. Let us hope. I
will let you know as soon as I try. Thanks again.
  Upload Photo  Select Gallery Photo  Attach Serial No List
Today's Featured Article - Show Coverage: Fair Weather Tractor - by Dave M.. No, Fair Weather isn't some rare brand. It's the kind you can't leave out in the rain. Here's how it happened. I had been casually looking for a tractor for weeks. I saw a few 9N's, but they had even fewer amenities than the 8N my Grandpa bought new in '52 with a Dearborn loader. That was 10 years before I was born, so I grew up thinking that 8N was the world's best tractor. Grandpa had greenhouses, with over half an acre under glass, and that 8N did almost everything. It was the only ... [Read Article]
