Re: Electrical Issue With International Harvester Frame Is H
Posted by Commoner#5 on February 16, 2015 at 09:25:19 from (108.49.89.244):
In Reply to: Re: Electrical Issue With International Harvester Frame Is H posted by Commoner#5 on February 16, 2015 at 06:06:14:
third party image
third party image
Did jump the negative terminal to the starter bolt and eliminate the battery disconnect switch. The frame was not hot and power was where it should have been. Reconnected the negative cable to the battery terminal that goes to the battery disconnect switch and the frame became hot. Put everything back together and gave her a go. Unfortunately I believe my battery is toast The starter turned over and wanted to go, but just did not have enough juice. Guess I need a new battery? Take a look at the attached pictures. One is of the back of my battery disconnect. The other shows the entire set up that has been giving me fits for several weeks. You can see the battery, battery disconnect switch, dashboard with push button, the toggle is just under to the right if you look closely. The new solenoid is to the left with new red and white wires. Hope this helps clarify what I am looking at.
  Upload Photo  Select Gallery Photo  Attach Serial No List
