Re: Electrical Issue With International Harvester Frame Is H
Posted by Jim Becker on February 17, 2015 at 08:58:16 from (173.84.243.159):
In Reply to: Electrical Issue With International Harvester Frame Is Hot posted by Commoner#5 on February 15, 2015 at 07:38:28:
You started with 12+ volts measured all over the place. You said the engine turned over when you jumped somehow. I don't see how you get from that to a bad battery.
Although I didn't follow all your places you measured voltage, the ones I did all suggest a bad ground. Were those readings taken with the ground disconnected? If so they look normal. If not you need to fix your ground connections.
You have clamp-on battery connections on your cables. Do they have clean connections to the cables? Connect the battery ground cable directly to the tractor frame, bypassing your disconnect switch. See if it starts that way. The more connections the heavy cables go through, the more potential trouble.
