I did have 12+ volts all over and these were taken with the ground connected, so it does look like the ground is the issue. I may be using the incorrect term, the starter turned over, not actually the engine. There does not seem to be enough power for that. This is an older battery, it is very cold here, and the tractor does not have a generator to recharge the battery once started. Sorry to leave these details out. It seems like the battery disconnect switch is my problem, at least at this point. I agree with the direct ground from battery to frame and bypass the battery disconnect to see if I can get her started. Will get the battery tested for a load at a local shop and see where we are, but it appears the battery may be beyond its useful purpose? Also will connect the negative battery terminal directly to the frame with good and clean connections. Thanks for your thoughts.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
