Posted by mkirsch on February 17, 2015 at 17:05:25 from (67.253.166.72):
In Reply to: IHC 340? posted by gabeS. on February 08, 2015 at 16:08:14:
140 PSI on the compression is phenomenal. If the smoke clears up after a few minutes, I would just run it as-is and not get too worked up over it. It may improve over time as you run it, because the oil may actually be coming up around a gummy ring, even with the phenomenal compression.
Today's Featured Article - Tuning Up Your Tractor: Cooling and Fuel Systems, Hoses and Belts - by Curtis Von Fange. Our tractor is coming right along. The old oil and filter has been taken to the recycler and the air filter replacement has breathed new life into our motor. Let's take a closer look, now, at the cooling system since it has to work so hard in the summer heat. Cooling systems can be real cantankerous in their old age. Radiator cores clog up with rust, lime or other mineral deposits and the fins clog up with weed seeds and debris. The metal headers slowly corrode away from years of use and
... [Read Article]
Latest Ad:
[More Ads]
