Re: Question on tranny gears swapping
Posted by D Slater on February 18, 2015 at 05:53:13 from (184.14.187.78):
In Reply to: Re: Question on tranny gears swapping posted by D Slater on February 17, 2015 at 14:37:23:
Correction my memory was off on the I-460. Checked and the I-460 unless a high utility, 504 and 340 all use the same 59 tooth sliding first gear and a 20 tooth gear driving the 59. Unless equipped with high speed first and reverse, then they used the same first gears used in a 300, 330, 350 or F-460.
Ring gear and pinion counts. F-340-49&14, I-340-49&16, F-460-49&15, I-460-50&18, F-504-50&13, I-504-49&16. High clearance internationals have the same R&P ratio as the farmall models most times.
Farmall models of 300 and 350 use the same ratio gears as a F-460 along with the first gear speeds.
  Upload Photo  Select Gallery Photo  Attach Serial No List
