Posted by tneathery on February 23, 2015 at 07:20:17 from (76.233.245.1):
I have a farmall 806 that had a broken camshaft. Have replaced the cam and per book I was using, lined up the timing marks on cam gear, crankshaft gear, and idler gear. Put it all back together and won't start. Get a little smoke out of stack and turns over good, but won't crank. Seems like a fuel issue, but good fuel flow through pump. Did I miss a critical step in timing like having piston on TDC or something like that????
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
