Re: 1939 famrall H propane No Throttle response
Posted by mkirsch on February 24, 2015 at 08:41:28 from (67.253.166.72):
In Reply to: 1939 famrall H propane No Throttle response posted by djsamuraii on February 24, 2015 at 08:01:03:
I don't know much about propane systems but the fact that propane "spews" out of the bottom, tells me something is VERY VERY WRONG with the carburetor.
The thing you're closing on the bottom seems like it might be the choke, which should be fully open when the tractor is running normally. It is only used for cold starting to richen the fuel mixture. Again I don't know much about propane systems so I am only guessing here.
Raw fuel should not be spewing from the carburetor, and closing the air intake is not the solution. That much I know.
