Re: Farmall 300 independent pto, broken drive gears, help
Posted by rjfcsa on February 26, 2015 at 16:18:58 from (50.109.73.197):
In Reply to: Farmall 300 independent pto, broken drive gears, help posted by D Slater on February 26, 2015 at 11:34:52:
Thanks for the input, should be easy to get the shaft out with the whole clutch housing sitting there by its self. I did not have a big enough 12 point socket with me when I was up at his house so when I go back I see if we can get the plug out.
Also is it very normal for these not to have a seasonal disconnect? this one just has a coupler there with a roll pin in one end.
Thanks,
Russel
