Re: Farmall 300 independent pto, broken drive gears, help
Posted by D Slater on February 26, 2015 at 11:34:52 from (184.14.187.78):
In Reply to: Farmall 300 independent pto, broken drive gears, help posted by rjfcsa on February 26, 2015 at 08:21:13:
Maybe hit something with the mower that started teeth breaking then momentum of the mower stripped more teeth. Or one tooth broke and wedged the gears.
With pto engaged the pto shaft at the transmission front should turn without much drag.
If that seems okay and the pto turns smooth you could change the oil in it to check for any metal.
You will need to remove the retaining ring lower pto shaft in center housing at rear bearing. Get the plug out and see if the bolt and washer holding the gear to shaft is still intact and tight. Remove the bolt and drive shaft out the rear. Best to wedge the pto gear to front on each side before driving out to keep pressure off the shaft front needle bearing.
12 point socket will work on the plug. Think its 1-5/8 but could be mistaken on the size.
  Upload Photo  Select Gallery Photo  Attach Serial No List
Today's Featured Article - The Day Tractor Lovers Dream About - by Angus Crawford. The day started at five o'clock on the morning of Friday, the January 29, 1999. My father, my sister, my uncle, my cousin and myself all climbed into my uncle's Toyota van. It was six thirty in the morning and we had a long day ahead. We traveled for six and a half hours to our destination - a little country town with a population of no more then one hundred and fifty people (57 of them being children under the age of thirteen). We arrived hoping to meet up with a man we knew had over one ... [Read Article]
