Posted by pete 23 on March 04, 2015 at 08:58:27 from (50.33.21.76):
In Reply to: 706 trans noise? posted by Jrw013 on March 01, 2015 at 18:58:48:
You are talking about a clunk with clutch engaged. At that point the throw out bearing should not be touching or turning unless you have no free play on clutch. You also say the noise sounds like near the clutch pedal. That would be rear of speed transmission or range transmission. I would make sure you have free travel on clutch pedal. Then put speed transmission lever between 2nd and 3rd gear which will be a neutral. No detent there so you have to feel your way. This will stop all speed transmission top shaft gear movement and mesh with lower gears while stopping all turning of range transmission. This should help you pin point area of noise.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
