I disagree (no flame) with your TA analysis. The use of the TA should be considered a real range selector. When in TA reduction, the one way clutch is not dragging (wearing from overrunning continuously) there are times when the tractor can freewheel down hill (usually when unloaded by draft equipment) the ground speed should never be allowed to be faster than that, 1 through 5 would go in direct. The issue is overspeeding the TA module possibly causing destruction. The TA one way clutch is continually wearing while in direct, due to the fact that it is continuously overrunning in direct. Use it as needed for pulling. Running all day in 3rd gear with the TA back is just fine. I have a 350U with the original TA and original main clutch with 9000 hours and one engine rebuild. It is still completely operational. Adjustment is needed every 2 years or so. Shift from TA direct to reduction as quickly as you can move the lever. Put it into direct just as quickly. The hydraulic TA in the big series is only different in that it will not freewheel in TA reduction. The hydraulic TA is not to be used as a deceleration brake, the Hydraulic locking clutch is not intended to survive that kind of thrashing. The pulling power is in reality controlled by a one way clutch. Again this is not intended to irritate. Jim
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
