Re: Coolant - Extended Discussion - Brian
Posted by Jim Becker on March 09, 2015 at 21:04:14 from (69.92.147.8):
In Reply to: Coolant - Extended Discussion - Brian posted by Jim Becker on March 07, 2015 at 19:24:16:
I was evidently in error when I said SuperTech was made by Prestone. Looks like I should have said Peak. This seems to be the correct MSDS.
http://msds.walmartstores.com/client/document?productid=ea1f6cff-d946-4594-be15-9eb71db141ad&action=MSDS&subformat=NAM
It lists ethelene glycol, diethelene glycol and "Proprietary sterile, aqueous, isotonic solution". No specific mention of 2-ethylhexanoic acid.
I had assumed the color coding was to distinguish compatible technologies rather than being marketing ploys. I guess that would make too much sense.
I hear you on the additive balancing act. Motor oil is the same way. Dumping snake oil in with an oil change is likely to do whatever is claimed but at the expense of something else that is equally important.
Today's Featured Article - Hydraulics - Cylinder Anatomy - by Curtis von Fange. Let’s make one more addition to our series on hydraulics. I’ve noticed a few questions in the comment section that could pertain to hydraulic cylinders so I thought we could take a short look at this real workhorse of the circuit. Cylinders are the reason for the hydraulic circuit. They take the fluid power delivered from the pump and magically change it into mechanical power. There are many types of cylinders that one might run across on a farm scenario. Each one could take a chapter in ... [Read Article]
