Posted by Jim Becker on March 07, 2015 at 19:24:16 from (74.32.103.31):
Brian,
In the other thread, you hit on several points I've been wrestling with. I've been using one of the floating ball testers and recently decided to throw it away and get a refractometer (although I haven't found one for $25). A year or so ago, I was moving to a considerably cooler climate so was testing coolant in everything. Some I was sure I had refilled with 50/50 mix were testing -10 or so, rather than the expected -34. My weakest mixture tested at +5, so I drained it into a couple plastic jugs. I set them outside during some of the -15 and colder weather this winter. They never froze. Also, the floating balls give no indication of too strong a mix. Using a cheap tester is just a path to wasting money on unneeded antifreeze.
I have seen multiple recommendations of the voltmeter test. Is it a useful test?
I've been trying to only buy extended life antifreeze that is labeled as compatible with all types of antifreeze. I'm not yet convinced whether such a thing exists and have yet to mix any into a Dex-Cool system. But I have been adding it to anything else. Are the "mix with anything" types really universal? Mostly I have been using Walmart's Super Tech, which is about as inexpensive as any full strength antifreeze.
Why does a Diesel have any special coolant requirements? It isn't like the fuel and coolant should ever touch each other. You mentioned wet cylinder liners. But there are plenty of wet sleeve gasoline engines out there. What is the difference?
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
