Re: Farmall 706 diese hard starting
Posted by pete 23 on March 12, 2015 at 17:29:11 from (50.33.12.37):
In Reply to: Farmall 706 diese hard starting posted by Farmall706D on March 12, 2015 at 12:47:42:
A 706 with a D-282 should pop right off after holding the glow plugs for about a minute in cool weather. Keep holding them when cranking and also open the throttle. Hold them for a while after starting to if exhaust is not clear. Any diesel has to have a good fast cranking speed to start. The timing is easily checked and should be 1 degree before TDC. You can go up to 3 degrees before tdc if it spits and sputter a bit at higher engine speeds. If the valves are recessed below new specs you will have a problem starting and cleaning up exhaust after it starts. Compression is everything .
  Upload Photo  Select Gallery Photo  Attach Serial No List
