Posted by chappie on March 13, 2015 at 21:22:36 from (208.74.247.249):
Last Fall I posted on here that my Farmall Super M tractor would not move after a cold spell. Thanks to the help on here, I found it was full of ice mixed with the oil in the tranny/rear end. After melting the ice, I drained it, cleaned it, and replaced the oil. That solved that problem.
However, just prior to that cold spell, I was driving down the road and was using 5th gear. I had to downshift for a hill. After that, I could not get it back into 4th or 5th gear. When I got home, I removed the shift lever and found the three slide rails were aligned as they should be. (Note: Earlier on the year I had the tip of the shift lever built up at a machine shop, because it was worn and occasionally would cause the slide rails to become misaligned).
After changing that fluid, I found it still would not go into 4 th + 5th gear, but it was too cold to mess with it. Now that the weather has warmed up, and the fluid level is up to snuff, I took it for a drive, got it nice and warm, and still it would not go into those gears. It works fine in Rev 1 2 and 3.
The shifter does go into the knotch, but I can not move the shifter back or forth. I tried to push and pull really hard, and even tapped (lightly) on the shift lever with a hammer. I wont go into those upper gears at all.
Anyone know what could be wrong?
PS. I made a boot out of an old tractor inner tube and a hose clamp and put it around the shift lever to prevent water from entering the gear lube again!
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
