Re: timing advance for my 300
Posted by pete 23 on March 15, 2015 at 17:20:35 from (50.33.12.37):
In Reply to: timing advance for my 300 posted by 1958johndeere620 on March 15, 2015 at 12:28:53:
If your advance is in reasonable condition you should have very little advance at low idle and like other poster said, 22 degrees before top dead center at full throttle. Set static timing(engine not running) at top dead center and then if dist is good you should hit the 22 at full throttle. The important part is the 22 for good engine performance and engine life. The low idle timing will just make the engine sound crappy if it cannot be adjusted to close to top dead center.
  Upload Photo  Select Gallery Photo  Attach Serial No List
