454 international starter says cranking?
Posted by longear on March 16, 2015 at 12:16:52 from (107.0.124.118):
once the starter is engaged it stays cranking. have to pull cable off battery to stop it.
took the starter solenoid to a rebuild shop ha says nothing wrong. I watched him test it.
Its not the ignition switch. I pulled the ignition wire off the battery then jumped from the terminal on solenoid to the + on battery remove and it still cranking.
is it possible that there is not enough voltage getting to the solenoid?
battery voltage at battery is 12.4.
I didnt think about checking the voltage at the solenoid til now.
