Re: w9 ?&%$#@!
Posted by Janicholson on March 18, 2015 at 06:34:39 from (199.17.6.26):
In Reply to: w9 ?&%$#@! posted by Rick in Iowa on March 17, 2015 at 19:32:52:
Blowing out the intake is a sure sign of a stuck/sticking valve. The only other possible way pressure can get into the intake would be the cam timing so far off that the intake valves are open on the up stroke of the piston. (not likely if some suction is felt. If you are not comfortable doing a leakdown test (putting air pressure into each cylinder, one at a time) you might need to get help.
I recommend just a bit more analysis before swapping that horse for a more "ready to go" animal. Jim
  Upload Photo  Select Gallery Photo  Attach Serial No List
