Well, it appears that coil does not require a ballast resister according to NAPA. I pull this from their website.
PRT840101 Printed in U.S.A. Form No. -3/144/81 INSTALLATION INSTRUCTIONS COILS FOR 12-VOLT SYSTEMS RESISTOR NOT REQUIRED 1. DO NOT INSTALL these coils on 12-volt systems equipped with a resistor or with resistance built into the wiring harness. 2. SELECT THE RIGHT COIL by referring to the application guide in the Catalog. 3. COIL POLARITY MUST BE CORRECT. If the negative battery post is grounded, the coil terminal marked (-) must be connected to the distributor. If the positive post is grounded, connect the coil marked (+) to the distributor. 4. All connection must be clean and tight. Make sure the coil high tension wire is firmly seated in the coil tower and the spark plug wires are firmly seated in the distributor cap towers.
Upload one or more videos to your post. Photo filesizes should be less than 300K and Videos, less than 2MB. Formats allowed are gif, jpg, png, ogg, mp4, mov, and avi. Be sure to use filenames without spaces or special characters, and filetypes of 3 digits lower case.
Today's Featured Article - Show Coverage: Fair Weather Tractor - by Dave M.. No, Fair Weather isn't some rare brand. It's the kind you can't leave out in the rain. Here's how it happened. I had been casually looking for a tractor for weeks. I saw a few 9N's, but they had even fewer amenities than the 8N my Grandpa bought new in '52 with a Dearborn loader. That was 10 years before I was born, so I grew up thinking that 8N was the world's best tractor. Grandpa had greenhouses, with over half an acre under glass, and that 8N did almost everything. It was the only
... [Read Article]
Latest Ad:
[More Ads]
