a) The coil is a NAPA ic14sb and there is no external ballast resistor. I'm on the 3rd one.
b) with the engine running, the alternator is putting out 14.3 volts (measured with a Fluke 117 multi-meter). I'm on the second one.
THAT VOLTAGE SEEMS FINE AND AROUND NORMAL
c) With a cold coil and tractor not running the resistance across the coil is 3.4 ohm using the same fluke meter.
SOUNDS LIKE ITS A 12 VOLT COIL IE NO BAllAST SHOULD BE NEEDED
d) When the tractor cuts out I notice the amp meter is 2/3 of the way between zero and 'D'. Something seems to be pulling mucho amps at that time.
COULD BE A SHORT SOMEWHERE OR A FAULTY VOLTAGE REGULATOR/ALTERNATOR IS DRAWING EXCESS CURRENT AND DROPPING BATTERY VOLTAGE SO LOW A WEAK SPARK MIGHT RESULT
Will swapping out the electronic ignition provide any logical / conceivable benefit?
I DONT THINK THE ELEC SWITCH IS THE PROBLEM BUT A SHORT SOMEWHERE CAUSING EXCESS CURRENT FLOW AND REDUCED VOLTAGE MAY BE????
Since it appears to be a 12 volt coil I cant explain why its overheating unless the switch is staying closed for such a long duty cycle that's overheating the coil SO PERHAPS THE SWITCH IS THE PROBLEM DESPITE MY THOUGHTS JUST ABOVE. If it stays closed a long time that could explain coil overheat and ignition failure.
BEST GUESSES 1) Alternator or Voltage Regulator is faulty causing a short reducing coil voltage causing weak spark
2) BUT if the coil is overheating and its a 12 volt coil and the Voltage Regulator and Alternator are all okay PERHAPS THE SWITCH IS FAILING AND REMAINING CLOSED WHICH WOULD OVERHEAT THE COIL PLUS CAUSE NO FIRING
Upload one or more videos to your post. Photo filesizes should be less than 300K and Videos, less than 2MB. Formats allowed are gif, jpg, png, ogg, mp4, mov, and avi. Be sure to use filenames without spaces or special characters, and filetypes of 3 digits lower case.
Today's Featured Article - Show Coverage: Fair Weather Tractor - by Dave M.. No, Fair Weather isn't some rare brand. It's the kind you can't leave out in the rain. Here's how it happened. I had been casually looking for a tractor for weeks. I saw a few 9N's, but they had even fewer amenities than the 8N my Grandpa bought new in '52 with a Dearborn loader. That was 10 years before I was born, so I grew up thinking that 8N was the world's best tractor. Grandpa had greenhouses, with over half an acre under glass, and that 8N did almost everything. It was the only
... [Read Article]
Latest Ad:
[More Ads]
