ot dodge diesel not charging 806 Curt
Posted by Ron in can on March 23, 2015 at 18:03:30 from (96.51.66.106):
I checked the batterys with drop voltage test the other day and both were .5 volts or less and everything was working ok then I took off the Boss snow plow and it stated showing no charge never shut truck off drove it about 4 miles and the gage dropped to 8 volts so I stopped and checked things unhooked the neg cable and it still did not move drove it home about 20 mins got home shut it off waited about 5 min and turned on the key and the gage jumped up to about 12 volts truck started and gage came up to 14+ in a few minutes and everything was fine until today when hooking up the boss plow it dropped again when checking this out I found something under the air intake there is a terminal block with 2 small wires coming from pos post on pass batt go to it and then they go across the front of the motor the front post on this block the side that goes across the front of the motor is loose on the block the wire is tight on the stud what does this do also I did a drop test on the pos cables and I got a reading of 6.54 volts out a booster cable across batterys and the gage went to normal take it off and it dropped to around 12 volts what is wrong
  Upload Photo  Select Gallery Photo  Attach Serial No List
Upload one or more videos to your post. Photo filesizes should be less than 300K and Videos, less than 2MB. Formats allowed are gif, jpg, png, ogg, mp4, mov, and avi. Be sure to use filenames without spaces or special characters, and filetypes of 3 digits lower case.
