Re: ot dodge diesel not charging 806 Curt
Posted by 806 Curt on March 24, 2015 at 05:28:48 from (206.126.211.30):
In Reply to: ot dodge diesel not charging 806 Curt posted by Ron in can on March 23, 2015 at 18:03:30:
It just sounds like you have an intermittent bad connection. That snowplow that you have on there ties right into your battery cables to work. That terminal block that you describe sounds like the solenoid that runs that plow. The wiring for the snow plow could have been installed different ways so its hard to know for sure exactly how your truck is set up. But the bottom line is on your voltage drop test you said you got that 6.54 volts across the positives on both batteries. This should not be possible. There HAS to be a poor connection somewhere between them. You will have to trace that wire and check every connection between. The reason the jumper cables make it work is because you are substituting a better connection.
  Upload Photo  Select Gallery Photo  Attach Serial No List
Upload one or more videos to your post. Photo filesizes should be less than 300K and Videos, less than 2MB. Formats allowed are gif, jpg, png, ogg, mp4, mov, and avi. Be sure to use filenames without spaces or special characters, and filetypes of 3 digits lower case.
