Re: 1972 IH 140 coil UPDATE w/Data
Posted by Bob M on March 24, 2015 at 14:40:11 from (67.240.160.94):
In Reply to: 1972 IH 140 coil UPDATE w/Data posted by Nawlens Gator on March 24, 2015 at 11:13:32:
A couple comments:
1 - Your voltage readings indicate the alternator is performing within specs. No problem there.
2 - Your coil is running WAY too hot. (It should run only slightly warmer than the ambient air around it.) And a hot coil means it's drawing way over design current. My guess is it's a "6 volt" coil and which is being supplied nearly double the design voltage. (BTW doubling the voltage QUADRUPLES the heat generated inside the coil).
I'm not familiar with your electronic ignition. It sounds however your coil is mismatched to the ignition. Or perhaps it needs an external ballast resistor to work with the coil.
  Upload Photo  Select Gallery Photo  Attach Serial No List
Upload one or more videos to your post. Photo filesizes should be less than 300K and Videos, less than 2MB. Formats allowed are gif, jpg, png, ogg, mp4, mov, and avi. Be sure to use filenames without spaces or special characters, and filetypes of 3 digits lower case.
