Re: 53 Super C Fast Hitch and Mounted Cornplanter
Posted by LMack on March 13, 2009 at 18:55:09 from (98.66.223.102):
In Reply to: 53 Super C Fast Hitch and Mounted Cornplanter posted by Jason B (Mi) on March 12, 2009 at 17:25:26:
There is also a hole in the bar parallel to the cylinder that must have a pin to lock the drawbar in place. If you are pulling an implement that requires the drawbar to be locked, insert a clevis in the top of the collar on the vertical bar. If you need a picture, I can make one for you. I do not recall that we did lock the drawbar often, but the clevis that came with the tractor was still in the tool box after 30 years of use.
