Farmall Tractors Discussion Board
Re: IH Lo Boy 185 clutch/transmission problem
Posted by JK MN on January 25, 1999 at 12:13:02:
In Reply to: IH Lo Boy 185 clutch/transmission problem posted by Mark Liptak on January 24, 1999 at 13:32:14:
Mark, That sheared bolt you found is very probably the bolt that attaches the clutch hub to the front of the transmission shaft. The clutch assembly "hangs" on the trans shaft right in front of the trans. Align hole in hub with trans shaft and install new bolt, and should be ready to go.
Post a Followup
: Re: Re: IH Lo Boy 185 clutch/transmission problem
