Re: Light Switch
Posted by Red Dave on January 22, 2001 at 09:47:05 from (64.41.23.27):
In Reply to: Light Switch posted by Bill VanHooser on January 21, 2001 at 17:39:23:
Bill, If your charging system is original, I believe that low charge, high charge, dim, bright is right. If you use the low/high charge feature, that is: high charge when it hasn't run for a while and short runs and: low charge when you use it a lot and on long runs, it will keep your battery in good condition. The trick to using 6 volt systems without a voltage regulator is to keep the battery charged without cooking it dry. Using the low/high switch should should help you do it.
Post A Followup
: Re: Re: Light Switch
Today's Featured Article - Identifying Tractor Noises - by Curtis Von Fange. Listening To Your Tractor : Part 3 - In this series we are continuing to learn the fine art of listening to our tractor in hopes of keeping it running longer. One particularly important facet is to hear and identify the particular noises that our ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
